Load/Unload Customizations window
Message 1 of 8
Hi all
Load/Unload Customizations window will appear every time when i open my autocad civil3D 2017. Please help me with this issue.
Please see attached screen shot
Thanks in advance
Replies (7)
Message 2 of 8
Can you screenshot the event viewer windows the only partially shown, along with the full path on right hand side of what is visible. I think that holders the key
Message 3 of 8
Hi @Anonymous
I don not think that's the problem, event viewer panorama appears cause of a syntax file error (pay item file). It can be solvable.
i attached it's screenshot.
Regards
Message 4 of 8
ok that's one thing ruled out.  But I've noticed that on the command line there is a _cuiunload command being called.  Can you expand the command window and screenshot that so we can see what is going on prior to the command being called.
Message 5 of 8
Jeew-m
Dear Friend,
Please follow this post and see if it applies to you as well.
https://forums.autodesk.com/t5/autocad-forum/aliasconcept-cuix-loads-against-my-will/td-p/3588370
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Message 6 of 8
Hi @Anonymous
Here is the screenshots of the text window.
Message 7 of 8
Hi @Jeew-m
Thanks but that did not helped me.
Message 8 of 8
Hi all
Problem as been solved
I reset my autocad civil3D settings to default.
Please go through attached screenshot.
Now everything back to original. All i need to customize my workspace.
Thanks to Everyone for there valuable effort to solve this issue.
Best regards
