List Sta/Off from object (not alignment)
deltacoolguy
deltacoolguy
Is there an quick and easy way to simply list the station/offset of something from an object such as a line, arc, etc.?
Not an alignment.  Not the Inquiry box?  I don't want to insert something that I will have to turn around and delete.  I just want to list the sta/off on the screen for quick reference similar to the read-out I get in the command line when I do Line and Arc Information (cglist).
Thanks.
Windows 10-64 Pro
8GB RAM (Home)
12GB RAM (Work)
AutoCAD Civil 3D 2019
Todd_Rogers
There is not. Simply because you mentioned "station". The station is from an alignment. You don't have stationing on objects.
Todd Rogers
Civil Administration
Joe-Bouza
As @Todd_Rogers  said. But it is simple enough to turn you object into an alignment that looks like your object and the has stations to list, label , display
Joe Bouza
lauri_barnhart
Hello, @deltacoolguy,
Did the information provided by @Todd_Rogers or @Joe-Bouza help you and answer your question?
If yes, please click on the "Accept Solution" button on the post(s) that solved your problem. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
Lauri | Community Manager
