Label to Total Number of Unconnected Pipes
demelza.kirwan
demelza.kirwan
I have a number of pipes (various runs) that are not connected (no structures and pipe breaks due to vertical and hoizontal bends). I need to show one label that shows the total length of pipe in the run in a label. Any ideas anyone?
AdammReilly
Unfortunately, all the methods I know require the pipes to be connected to define the 'run'. Without those connections, there isn't a clear way to know if a pipe belongs in the run.
You might be able to use dynamo to work that out, but without the connections, you'd end up having to select the pipes manually or by a path object (alignment, polyline).
Adam Reilly
Civil 3D 2026
Creator A16 AI+ A3HVFG
Windows 11 Pro
AMD Ryzen AI 9 365 w/ Radeon 880M
LinkedIn
Group Leader badge
Austin CADD User Group
LinkedIn | Discord
Civil 3D Certified Professional
bhavani_sankuratri
Hello @demelza.kirwan
Did the information provided by @AdammReilly  help you and answer your question?
If yes, please click on the "Accept Solution" button on the post(s) that solved your problem. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
Bhavani Sankuratri | Community Manager
bhavani_sankuratri
Hi @demelza.kirwan
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
All the best,
