Civil 3D Forum
Linetype and annotation
2 REPLIES 2
srowland4PKTE
303 Views, 2 Replies
Hello hello.
Today's query is in regard to using linetypes for Utility Plan sheets. In other environments I have used a linetype that is written to show the type ( W/ST/E/G ) and had a notation along the run with size. My current workplace has a method of using line labels elevations to create the tags. I find this later method of notation to have a number of flaws that can become unnecessary issues.
I am hopeful you guys can steer me towards information on writing better complex linetypes that will also adhere to ratio changes needed between Plan View needs.
thank you.
2 REPLIES 2
in reply to: srowland4PKTE
Print out the acad.lin file and look into the styles that have text in it. Copy that linetype code to the end of th file and change the text added in the code. Make sure you rename the lineytpe to what you need.  Look into the help if you need more info.  You might want to make a copy of the original file and rename it. HTH
rl_jackson
These are not perfect by any means, as I created them on the fly for a project I was working on. But I use linetypes to do this.
*WATER_LINE_1,Existing Water ---- W ---- W ---- W ----
A,1,-.07,["W",STANDARD,S=.06,R=0.0,X=-0.04,Y=-.03],-.07
*WATER_LINE_2,Existing Water ---- W ---- W ---- W ----
A,.5,-.07,["W",STANDARD,S=.06,R=0.0,X=-0.04,Y=-.03],-.07
*WATER_LINE_3,Existing Water ---- W ---- W ---- W ----
A,.25,-.07,["W",STANDARD,S=.06,R=0.0,X=-0.04,Y=-.03],-.07
*WATER_LINE_4,Existing Water ---- W ---- W ---- W ----
A,.125,-.07,["W",STANDARD,S=.06,R=0.0,X=-0.04,Y=-.03],-.07
*GAS_LINE_2,Existing Gas line ----G----G----G----G----G----G--
A,.5,-.07,["G",STANDARD,S=.06,R=0.0,X=-0.04,Y=-.03],-.07
*GAS_LINE_1,Existing Gas line ----G----G----G----G----G----G--
A,1,-.07,["G",STANDARD,S=.06,R=0.0,X=-0.04,Y=-.03],-.07
*SEWER_LINE_1,Sewer line ----SS----SS----SS----SS----SS----SS--
A,1,-.08,["SS",STANDARD,S=.06,R=0.0,X=-0.05,Y=-.03],-.08
*SEWER_LINE_2,Sewer line ----SS----SS----SS----SS----SS----SS--
A,.5,-.08,["SS",STANDARD,S=.06,R=0.0,X=-0.05,Y=-.03],-.08
*4_SEWER_1,4" Sewer line ----4" SS----4" SS----4" SS----4" SS----4" SS----4" SS--
A,1,-.13,["4%%34 SS",STANDARD,S=.06,R=0.0,X=-0.1,Y=-.03],-.13
*4_SEWER_2,4" Sewer line ----4" SS----4" SS----4" SS----4" SS----4" SS----4" SS--
A,.5,-.13,["4%%34 SS",STANDARD,S=.06,R=0.0,X=-0.1,Y=-.03],-.13
*6_SEWER_1,6" Sewer line ----6" SS----6" SS----6" SS----6" SS----6" SS----6" SS--
A,1,-.13,["6%%34 SS",STANDARD,S=.06,R=0.0,X=-0.1,Y=-.03],-.13
*6_SEWER_2,6" Sewer line ----6" SS----6" SS----6" SS----6" SS----6" SS----6" SS--
A,.5,-.13,["6%%34 SS",STANDARD,S=.06,R=0.0,X=-0.1,Y=-.03],-.13
*8_SEWER_1,8" Sewer line ----8" SS----8" SS----8" SS----8" SS----8" SS----8" SS--
A,1,-.13,["8%%34 SS",STANDARD,S=.06,R=0.0,X=-0.1,Y=-.03],-.13
*8_SEWER_2,8" Sewer line ----8" SS----8" SS----8" SS----8" SS----8" SS----8" SS--
A,.5,-.13,["8%%34 SS",STANDARD,S=.06,R=0.0,X=-0.1,Y=-.03],-.13
*10_SEWER_1,10" Sewer line ----10" SS----10" SS----10" SS----10" SS----10" SS----10" SS--
A,1,-.15,["10%%34 SS",STANDARD,S=.06,R=0.0,X=-0.13,Y=-.03],-.15
*10_SEWER_2,10" Sewer line ----10" SS----10" SS----10" SS----10" SS----10" SS----10" SS--
A,.5,-.15,["10%%34 SS",STANDARD,S=.06,R=0.0,X=-0.13,Y=-.03],-.15
*12_SEWER_1,12" Sewer line ----12" SS----12" SS----12" SS----12" SS----12" SS----12" SS--
A,1,-.15,["12%%34 SS",STANDARD,S=.06,R=0.0,X=-0.13,Y=-.03],-.15
*12_SEWER_2,12" Sewer line ----12" SS----12" SS----12" SS----12" SS----12" SS----12" SS--
A,.5,-.15,["12%%34 SS",STANDARD,S=.06,R=0.0,X=-0.13,Y=-.03],-.15
*CHAINLINK_2, Chain Link Fence with spaces
A,.25,-.03,["\U+25CB",STANDARD,S=.06,R=0.0,X=-0.025,Y=-.0225],-.03
*CHAINLINK_1, Chain Link Fence with spaces
A,.5,-.03,["\U+25CB",STANDARD,S=.06,R=0.0,X=-0.025,Y=-.0225],-.03
*VINYL_1, Vinyl Fence with spaces
A,.5,-.03,["\U+25CA",STANDARD,S=.06,R=0.0,X=-0.02,Y=-.03],-.03
*VINYL_2, Vinyl Fence with spaces
A,.25,-.03,["\U+25CA",STANDARD,S=.06,R=0.0,X=-0.02,Y=-.03],-.03
*IRON_1, Wrought Iron Fence with spaces
A,.5,-.03,["\U+25A1",STANDARD,S=.06,R=0.0,X=-0.025,Y=-.02],-.03
*IRON_2, Wrought Iron Fence with spaces
A,.25,-.03,["\U+25A1",STANDARD,S=.06,R=0.0,X=-0.025,Y=-.02],-.03
*WOOD_1, Wood Fence with spaces
A,.5,-.03,["//",STANDARD,S=.06,R=0.0,X=-0.02,Y=-.03],-.03
*WOOD_2, Wood Fence with spaces
A,.25,-.03,["//",STANDARD,S=.06,R=0.0,X=-0.02,Y=-.03],-.03
*BARBWIRE_1, Barbwire Fence with spaces
A,.5,-.03,["X",STANDARD,S=.06,R=0.0,X=-0.02,Y=-.03],-.03
*BARBWIRE_2, Barbwire Fence with spaces
A,.25,-.03,["X",STANDARD,S=.06,R=0.0,X=-0.02,Y=-.03],-.03
*15_CMP_1,15" CMP ----15" CMP----15" CMP----15" CMP----15" CMP----15" CMP----15" CMP--
A,1,-.15,["15%%34 CMP",STANDARD,S=.06,R=0.0,X=-0.13,Y=-.03],-.15
*15_CMP_2,15" CMP ----15" CMP----15" CMP----15" CMP----15" CMP----15" CMP----15" CMP--
A,.5,-.15,["15%%34 CMP",STANDARD,S=.06,R=0.0,X=-0.13,Y=-.03],-.15
*18_CMP_1,18" CMP ----18" CMP----18" CMP----18" CMP----18" CMP----18" CMP----18" CMP--
A,1,-.15,["18%%34 CMP",STANDARD,S=.06,R=0.0,X=-0.13,Y=-.03],-.15
*18_CMP_2,18" CMP ----18" CMP----18" CMP----18" CMP----18" CMP----18" CMP----18" CMP--
A,.5,-.15,["18%%34 CMP",STANDARD,S=.06,R=0.0,X=-0.13,Y=-.03],-.15
*24_CMP_1,24" CMP ----24" CMP----24" CMP----24" CMP----24" CMP----24" CMP----24" CMP--
A,1,-.15,["24%%34 CMP",STANDARD,S=.06,R=0.0,X=-0.13,Y=-.03],-.15
*24_CMP_2,24" CMP ----24" CMP----24" CMP----24" CMP----24" CMP----24" CMP----24" CMP--
A,.5,-.15,["24%%34 CMP",STANDARD,S=.06,R=0.0,X=-0.13,Y=-.03],-.15
*15_HDPE_1,15" HDPE ----15" HDPE----15" HDPE----15" HDPE----15" HDPE----15" HDPE----15" HDPE--
A,1,-.12,["15%%34 HDPE",STANDARD,S=.06,R=0.0,X=-0.13,Y=-.03],-.25
*15_HDPE_2,15" HDPE ----15" HDPE----15" HDPE----15" HDPE----15" HDPE----15" HDPE----15" HDPE--
A,.5,-.12,["15%%34 HDPE",STANDARD,S=.06,R=0.0,X=-0.13,Y=-.03],-.25
*18_HDPE_1,18" HDPE ----18" HDPE----18" HDPE----18" HDPE----18" HDPE----18" HDPE----18" HDPE--
A,1,-.12,["18%%34 HDPE",STANDARD,S=.06,R=0.0,X=-0.13,Y=-.03],-.25
*18_HDPE_2,18" HDPE ----18" HDPE----18" HDPE----18" HDPE----18" HDPE----18" HDPE----18" HDPE--
A,.5,-.12,["18%%34 HDPE",STANDARD,S=.06,R=0.0,X=-0.13,Y=-.03],-.25
*24_HDPE_1,24" HDPE ----24" HDPE----24" HDPE----24" HDPE----24" HDPE----24" HDPE----24" HDPE--
A,1,-.12,["24%%34 HDPE",STANDARD,S=.06,R=0.0,X=-0.13,Y=-.03],-.25
*24_HDPE_2,24" HDPE ----24" HDPE----24" HDPE----24" HDPE----24" HDPE----24" HDPE----24" HDPE--
A,.5,-.12,["24%%34 HDPE",STANDARD,S=.06,R=0.0,X=-0.13,Y=-.03],-.25
*15_RCP_1,15" RCP ----15" RCP----15" RCP----15" RCP----15" RCP----15" RCP----15" RCP--
A,1,-.15,["15%%34 RCP",STANDARD,S=.06,R=0.0,X=-0.13,Y=-.03],-.15
*15_RCP_2,15" RCP ----15" RCP----15" RCP----15" RCP----15" RCP----15" RCP----15" RCP--
A,.5,-.15,["15%%34 RCP",STANDARD,S=.06,R=0.0,X=-0.13,Y=-.03],-.15
*18_RCP_1,18" RCP ----18" RCP----18" RCP----18" RCP----18" RCP----18" RCP----18" RCP--
A,1,-.15,["18%%34 RCP",STANDARD,S=.06,R=0.0,X=-0.13,Y=-.03],-.15
*18_RCP_2,18" RCP ----18" RCP----18" RCP----18" RCP----18" RCP----18" RCP----18" RCP--
A,.5,-.15,["18%%34 RCP",STANDARD,S=.06,R=0.0,X=-0.13,Y=-.03],-.15
*24_RCP_1,24" RCP ----24" RCP----24" RCP----24" RCP----24" RCP----24" RCP----24" RCP--
A,1,-.15,["24%%34 RCP",STANDARD,S=.06,R=0.0,X=-0.13,Y=-.03],-.15
*24_RCP_2,24" RCP ----24" RCP----24" RCP----24" RCP----24" RCP----24" RCP----24" RCP--
A,.5,-.15,["24%%34 RCP",STANDARD,S=.06,R=0.0,X=-0.13,Y=-.03],-.15
Rick Jackson
Survey CAD Technician VI
Rail Community
