LIDAR Scaleing
LIDAR Scaleing
Message 1 of 17
LIDAR Scaleing
Two Questions:
1. How do I go about converting LIDAR files from metric to English.
2. If I create a new surface and the bring in the LIDAR info I need into the surface can the LIDAR Files then be deleted?
Both questions are for Vrs 2015
Dave Z.
Replies (16)
Message 2 of 17
Pointdump
Dave Z,
Depends. In what format are they? LAS, LAZ, zLAS, ASCII? Best to post 'em. If the Forum won't accept that format, zip them up.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 3 of 17
LAS Zone 14-15 NAD 83
I can't get the zip file to attach
Message 4 of 17
Pointdump
Dave Z,
What size is your LAS file? The Forum will accept up to 75 MB. Zipping should work. How is it hanging up?
"Zone 14-15 NAD 83"
Is that UTM83-14 or UTM83-15?
Dave S
Dave Stoll
Las Vegas, Nevada
Message 5 of 17
I have no clue. I will get on the kansas usgs site and see what I can find
Message 6 of 17
Pointdump
Dave Z,
When you create your point cloud database (bringing in your LAS file), you specify the drawing's Coordinate System and the Point Cloud's Coordinate System. It should transform automatically. With data we can test.
Dave S
Dave Stoll
Las Vegas, Nevada
Message 7 of 17
Ok the site has
Projection data: UTM zones 14-15/Nad 83
I have created the point cloud. Can the Coord system be changed. Or do I need to start over?
Message 8 of 17
What is going on with this site. I didn't mark it as excepted
Message 9 of 17
Ok no mater what coordinate zone I use my lidar point elevations are still showing in Meters and not in feet. They need to be in Feet.......ggrrrrrr.
AutoCAD needs to add a conversion process in the program.
PS The US switch back to Imperial several years back. Why is metric still being used.
dave z.
Message 10 of 17
Pointdump
Dave Z,
"Why is metric still being used."
Dunno. But even if the US went metric tomorrow, there would still be a LOT of drawings and data out there using different units and Coordinate Systems.
I still think C3D will transform that data automatically. Please post your data.
Dave S
Dave Stoll
Las Vegas, Nevada
Message 11 of 17
The las file is over 600mb. Will try and zip the file or see if i can do just a small part in the morning
Message 12 of 17
Pointdump
Dave Z,
600MB? That's a serious LiDAR point cloud! Is it the ENTIRE state of Kansas? Are the points classified? Link please.
You'll need some tools to chop that up, something like LAStools:
https://rapidlasso.com/lastools/
Dave S
Dave Stoll
Las Vegas, Nevada
Message 13 of 17
It's what they call a panel. Which their site says is 5000m sq.
I will try and post link to their site
Message 14 of 17
Pointdump
Dave Z,
I played with some Minnesota Data in UTM83-15 Meters this morning(LAS file attached) and Civil 3D does indeed handle the elevation conversion from Metric to Feet. I assigned one drawing UTM83-15 Meters and one UTM83-15 Survey Feet. Here's the results:
Dave S
Dave Stoll
Las Vegas, Nevada
Message 15 of 17
Ok Got it to Work this time. It is now readying the elevations in feet as shown on your images above. Not sure what was going on I didn't do anything different. Unless something cleared its self when I shut down the system for the night and restarted this morning.
Ok so now to get the elevations to read correctly. (Say 1500) I Take 427.277x3.2808=1500.00. Then 1500.00-472.277=1,027.723
Then adjusting the surface up 1,027.723 to get correct datum elevations.
Message 16 of 17
Pointdump
Dave Z,
"Take 427.277x3.2808=1500.00. Then 1500.00-472.277=1,027.723
Then adjusting the surface up 1,027.723 to get correct datum elevations."
What happened? Wrong vertical Datum? Why do you have to adjust them?
Dave S
Dave Stoll
Las Vegas, Nevada
Message 17 of 17
Dave
Take a look at your last image above and note the min. & Max elevations.
When I adjust the surface base on your last post the datum elevations read as normal.
Also when I hover over the surface the datums read correctly.
Thanks for all the help. Really appreciate it. Watch for my new post...coming soon.
Dave Z.
