Mensagem 1 de 6
- Marcar como novo
- Favorito
- Inscrever-se
- Emudecer
- Inscrever-se no RSS Feed
- Realçar
- Imprimir
- Relatório
Hi all,
Is there a way to set the level of detail default to off (Civil 3D 2018)? I want to open a drawing and have the default setting be level of detail off.
It appears when the first window popped up and I pressed turn on and checked the do not show message again box, that the system defaulted to turning on the feature on for every drawing that qualifies. I even opened a drawing, turned it off, saved, closed, and reopened the drawing and it still defaulted to on.
Any ideas? I saw a post that mentioned adding a few lines of code to the acaddoc.lsp file. But I did not want to go messing with autocad install files without further investigating alternative methods.
Solucionado! Ir para Solução.
