how to fix multiple low and high levels?
Please find the attachment attached here with  csv format and screenshot.
Before vertical alignment i need to fix the low and high levels. how to fix multiple points in civil 3d
tcorey
I sorted your data by elevation and nothing looks wacky in your csv file. The elevations run from approximately 316 to 387.
That looks like a surface profile, so my guess is that your surface has had breaklines added, and those breaklines are at 0 elevation.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
jroot
Can you describe what you mean by "fix"?
Are you looking to remove the high & low outliers of elevation in your points?
