Launch "-layer" command in CUI macro...
Jerry_Barnes
Jerry_Barnes
I want to create a toolbar macro that creates a new layer called "_xref", makes it current, then launches the XATTACH command. Problem is, I can't get past the Layer command stopping the macro at the command line (or a dialog box) asking what, exactly, I want to do. (e.g. Make, Set, New, etc.). The stoppage essentially kills the purpose of the macro.
Any ideas? Thanks.
tcorey
^C^C(command "-Layer" "M" "_Xref" "");^C^CXattach;
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
cwr-pae
If you are using version 2018 and later you can use the system variable xreflayer to set a layer name for xrefs to be placed on automatically. Even if not present in the drawing it wail be created when an xref is attached.
A variation of @tcorey's macro is: ^C^C-layer;n;xref;c;150;xref;;clayer;xref;xattach;
which creates the layer xref, changes the color to 150, makes the layer current and start the xattach command.
Jerry_Barnes
Thanks, Tim. As usual, U Da Man!
