Thank you for clarifying. Using the text file named lambert.txt in post 3 of this thread, you can insert those points into India-LCC projection and they will be at the location of the Thal Canal. Your explanation of the situation was not clear and created confusion when trying to place them in a drawing. As it turns out, they are using Kalianpur1975.India-I (EPSG 24378) and not Lambert Conical Projection.
Someone else, not you, has already converted them from India-LCC to Kalianpur75 zone-I. Another possibility is the coordinates, which appear to be a proposed or recently constructed canal, were shot in Kalianpur75 and were never in India LCC to begin with. At any rate, you and everyone else, must treat those coordinates as Kalianpur75. You may then insert the points into any projection, including India-LCC, and they will appear at the Thal site. If the coordinates are stated in meters, which they are, the points will be on dry land, not the ocean. Since the units in lamber.txt are indeed meters and not feet, you'll be fine using this file.
Try this:
- Start from a fresh, new, clean metric template. Don't use an imperial template.
- Switch from Civil 3D workspace to Planning and Analysis workspace.
- MAPCSASSIGN on command line. Search India-LCC. Select India-LCC and assign it to your drawing.
- Go to Insert tab/Import panel/MAP IMPORT icon. Make Files of type ASCII Point File from the dropdown menu then browse to lambert.txt, select it, then OK.
- Formatting/Select Formatting/choose ENZ (space delimited) from dropdown. A portion of your data will appear in the preview section.
- Coordinate System assignment/Enter code/Click the Coordinate System icon (see image-1). In search, enter India-LCC. Highlight India-LCC, then click SELECT button. (By clicking SELECT, you have just informed Map3D to perform a transformation on lambert.txt from Kalianpur75 to India-LCC.)
- Click OK. Your points will appear in your map. Zoom in and turn on Bing imagery. Select all points, go to Properties palette and change Scale to 5000 (see image-2).
1-Map Import: Choose ENZ (space delimited) format. Inform M3D your points are using Kalianpur 1975 projection by clicking CoordSys button, then select Kalianpur1975.India-I.
2-Make your points big. Select all poionts, then scale them to 5000 in Properties palette.
Chicagolooper
