Civil 3D Forum
Label text size doesn't match in Paper space and model space
7 REPLIES 7
Message 1 of 8
Wilson.WanH8Q64
387 Views, 7 Replies
I added contour label for the contour line than xref to another drawing. In paper space , the text is 2000 time larger. What can I do to set the size of the text same in different space?
7 REPLIES 7
Message 2 of 8
Pointdump
in reply to: Wilson.WanH8Q64
Hi Wilson,
Anytime I see 3 zeroes mentioned I think Meters --> Millimeters problem.
Can you post both your drawing and the Xref?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 3 of 8
Wilson.WanH8Q64
in reply to: Pointdump
Thanks for your reply. When I xref the drawing. it showed normaly in the model space. But in paper space,  the size of text just 2000 bigger
Message 4 of 8
Jeff_M
Please post the dwg file so you can get it fixed much more quickly.
Jeff_M, also a frequent Swamper
Message 5 of 8
C3D_TomR
@Wilson.WanH8Q64
What is the (annoscale) annotation scale setting in model space and what is the setting within the viewport? They should match exactly. If not, you'll see a difference in the text size between the model tab and model space within the viewport.
Tom Richardson
Autodesk Certified Professional in Civil 3D for Infrastructure Design
Autodesk AEC Community Blog
Crossing the line with Civil 3D
Twitter | LinkedIn
Austin CAD User Group Resources
Blog | Discord | LinkedIn
Autodesk Group Network Leader
Message 6 of 8
Check your page setup in paper space.  I suspect your settings for model space units to paper space units isn't right.
Mark Mccall
CAD Mangler
Hammer Land Engineering
Linkedin
Message 7 of 8
Wilson.WanH8Q64
in reply to: Jeff_M
Just like this one. I tried different setting already. And also, how can I change the unit in Label style composer box. My drawing is meter but inside it is still inch.
Message 8 of 8
Your surface is very large (9,688,004 sq.m)  and the label style is very large, 20 mm.   When you place that on a small sheet of paper at a large scale (viewport was +1:20000) the labels are going to be HUGE.
A 2mm label height would be more suitable.  Or, a much larger sheet.
Mark Mccall
CAD Mangler
Linkedin
Rail Community
