Issue with Ribbon Tabs in Planning and Analysis
emelia_norling
emelia_norling
Community Visitor
Community Visitor
Hi.
I am experiencing a problem with the ribbon tabs under "Planning and Analysis." Previously, I could see options like Home, Insert, Annotate, Feature Edit, and Create, but now I only see "Quadri."
I suspect this might be related to the "Workspace Contents," where everything under the ribbon is marked as "unresolved."
Could you please assist me in resolving this issue?
Thank you for your help!
andrewpuller3811
This happens when a cuix file gets moved or renamed and Civil 3d/Autocad cannot find it to load the ribbon parts from.
Can you check in the Civil 3d support folder and see if the file map_planninganalysis.cuix is present?
If you are not sure where the support folder is - past the line below in the address bar of windows explorer (change 2023 to the version you are using)
%appdata%\Autodesk\C3D 2023\enu\support
If that file is not there, you can find a copy of it in C:\Program Files\Autodesk\AutoCAD 2023\UserDataCache\Support
(Change the 2023 to whatever version you are using)
Copy the file from this location to the location above.
Close and reopen civil 3d.
This is assuming civil 3d is installed in the default location and your map_planninganalysis.cuix was previously in the default location.
If this does not work, we can try other steps.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 11
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2023
