I have a project with hundreds of point files associated with it. I was supposed to be being sent point files as they came in, but today I discovered I am missing some and now I'm trying to figure out if some of the files have points in areas where I need data.
So, I need to be able to import a bunch of files at the same time. Normally I would do this via the task manager in Civil3D, except that most of the point files have control points in them with point numbers that start with a letter which Civil3D will not read for whatever reason, and I can't just go through and edit all the point files.
Carlson WILL read these files, but I can only seem to import one point file at a time which would be very tedious for this task. Is there not some way to do a batch import of multiple csv files like Civil3D will do?
