Is there a way to create query points based on location and date imported?
bill2NMLX
Message 1 of 25
bill2NMLX
What going on I have is three groups of points that were each imported on progressive days. We now have polyline boundaries around each date. But these points have some overlap from day to day with older points.  We would like to create a query or pt group of the latest points and only get the newest points ignoring the older ones that the newer ones overlap.
Is this possible in C3D using either a map query or maybe even programing with Dynamo? Any ideals of things to try would be greatly appreciated.
Bill Neuhauser, P.E.
CGS LLC.
Replies (24)
Message 21 of 25
Joe-Bouza
@bill2NMLX @Let’s forget the donut hole for moment and get back to the points and my last question.
Do you need to remove the points prior to 8/3 within the boundary as defined? If so, why can’t they be removed by a selection set ?
Joe Bouza
Message 22 of 25
Joe-Bouza
What are these donuts anyway.
Joe Bouza
Message 23 of 25
Joe-Bouza
lost my post.
what is so complicated about your surface that the points to remove can’t be selected with a crossing window ?
what is this tinn surface that has blank spots in it that need such finesse?
Joe Bouza
Message 24 of 25
chriscowgill7373
I didnt read all the little details of everyones posts (although I probably should have) I dont understand why your surface definition cant be setup to just use a point group, the one you want to use for that particular surface.  Or are you wanting to keep some of the points from the old surfaces, but not others...
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2024 on Windows 10
Message 25 of 25
Joe-Bouza
Good luck getting a straight answer 😮
Joe Bouza
