Civil 3D Forum
Is there a Way to add surface to multiple alignments at once (to save time)
7 REPLIES 7
Message 1 of 8
2705 Views, 7 Replies
Looking to save time while creating profile views
there has to be a way to
1. Label multple alignments at once.
2. add surfaces to multiple alignments at once etc.
7 REPLIES 7
Message 2 of 8
MMcCall402
1) Not as far as I know.  You can however add multiple alignment labels saved as a Label Set to an alignment.  A set of labels can be applied to an alignment during its creation by default.
2) Again, not as far as I know.  I did notice that when you select an alignment the ribbon will show a Surface Profile button that will take you right to the screen for choosing the surface.
Mark Mccall
CAD Mangler
Hammer Land Engineering
Linkedin
Message 3 of 8
Neilw_05
As Mark said, you cannot create surface profiles for more than one alignment at a time. The Profile from Surface dialogue allows you to select multiple alignments for sampling, but when you accept and return to the drawing, the profiles do not get created for the added alignments.
This is one of those quirks you learn from experience. You won't learn it from a canned training course or tutorials.
There are LOTS of quirks to learn.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 4 of 8
makourani
You can use Dynamo to work in bulk. Did people born with experience??? as I understand from the upper rude reply.
Message 5 of 8
cneelyUFTR2
There are 3rd party tools for these things. The app store may have some free ones. Below are links to two I know of.
https://apps.autodesk.com/CIV3D/en/Detail/Index?id=6048968207373152372&appLang=en&os=Win64
https://www.civilcadls.com/custom-apps
Message 6 of 8
Neilw_05
in reply to: makourani
You can solve this with any script such as Dynamo. All of those options require a learning curve. Do you have an Out Of The Box solution?
WIN 10 64 PRO
Message 7 of 8
Joe-Bouza
in reply to: Neilw_05
Dynamo is in the box :o.... lol just kidding
Joe Bouza
Message 8 of 8
Neilw_05
So is the script tool and LISP if you want to look at anything that is available with the software. All of those options provide a solution though.
WIN 10 64 PRO
Rail Community
