Civil 3D Forum
Intersection not displaying correctly
5 REPLIES 5
rdavisMX6RG
235 Views, 5 Replies
I upgraded to 2024 last week and since then none of my intersections are forming right at all.
I go through the process of either doing the intersection 1st or alternatively split region in existing corridor at the T jucntion intersection.  I select the correctassembly for each road but this keeps coming up.  I did not have this issue in 2023
I believe it is to do with targets but is anyone able to help me to get the junction looking right, even if there is a video you can direct me to?
Thanks in advance
Labels (1)
5 REPLIES 5
ecfernandez
in reply to: rdavisMX6RG
Hi @rdavisMX6RG, I hope you are doing well. It seems to me you must take a look at your baselines and targets. I believe this video will give you the ideas you need to solve your problem:
Video: Simplifying Civil 3D Corridor Modeling using Contextual Tools
I hope this helps. Best regards!
Camilo Fernández
Civil engineer | Specialist in design, construction, and maintenance of roadways
LinkedIn
m_kingdon
Are you able to upload the drawing? It is hard to assist you with only a screenshot of the surface.  We can't see anything relating to the corridor.
@ecfernandez is probably right, it looks like a baseline / targeting issue.
Mike Kingdon
Civil 3D Zealot
nkiakas
Hi @rdavisMX6RG
The attachment shows that your corridor lost the targets
Can you share your file?
rdavisMX6RG
Thanks all for the replies.
In this instance I found my issue.  When I was doing the corridor, 3DC formed new assemblies and they were inserting for what I had previously used as defaults.  I amended the assemblies and bingo, back to normal.
I will take a look at a targeting video link as not too hot on them anyway.
Thanks again
ecfernandez
Hi @rdavisMX6RG, thanks for letting us know you already figured it out. Best regards!
Camilo Fernández
LinkedIn
Rail Community
