I upgraded to 2024 last week and since then none of my intersections are forming right at all.
I go through the process of either doing the intersection 1st or alternatively split region in existing corridor at the T jucntion intersection. I select the correctassembly for each road but this keeps coming up. I did not have this issue in 2023
I believe it is to do with targets but is anyone able to help me to get the junction looking right, even if there is a video you can direct me to?
Thanks in advance
Solved by rdavisMX6RG. Go to Solution.
Hi @rdavisMX6RG, I hope you are doing well. It seems to me you must take a look at your baselines and targets. I believe this video will give you the ideas you need to solve your problem:
Video: Simplifying Civil 3D Corridor Modeling using Contextual Tools
I hope this helps. Best regards!
Are you able to upload the drawing? It is hard to assist you with only a screenshot of the surface. We can't see anything relating to the corridor.
@ecfernandez is probably right, it looks like a baseline / targeting issue.
Mike Kingdon
Civil 3D Zealot
Thanks all for the replies.
In this instance I found my issue. When I was doing the corridor, 3DC formed new assemblies and they were inserting for what I had previously used as defaults. I amended the assemblies and bingo, back to normal.
I will take a look at a targeting video link as not too hot on them anyway.
Thanks again
Hi @rdavisMX6RG, thanks for letting us know you already figured it out. Best regards!
