Hi guys,
I am having some targeting issues within my corridor properties, mainly with what seems my kerb returns. if someone could pls look at the drawing attached and tell me what they think is causing it so I can amend.
Got alot further this time by using the standard assemblies civils gives you and then changing where i need - only issue is still the kerb returns, where they're still targeting the wrong place leaving a hole in the middle of the corridor?
Each assembly has two targets for offset and elevation. The targets are the same for both assemblies. The target are the branch road centerline alignment and profile and the feature line or alignment/profile of the edge of the main road. Check the lane assembly, some have to have the targeting enabled for length and/or elevation.
If you still have problems, can you post the drawing?
