INTERNAL ERROR: !dbobji.cpp@8440: eNotOpenForWrite
Has anyone ever encountered the below error?
I was working in the planning and analysis tab, editing a legend style when AutoCAD crashed. Specifically, I was trying to change the scale of a hatch pattern. AutoCAD didn't recover data and I keep getting the above error. I tried to open on another machine under a different license and got the same result.
Any help is much appreciated.
J.FOCHT
Check this link out. It may be helpful.
If this helps you then hit the LIKE button or mark as an ACCEPTED SOLUTION!
Thank You!
Jonathan Focht
J.FOCHT
Sorry, I forgot the link!
https://forums.autodesk.com/t5/autocad-plant-3d-forum/error-quot-internal-error-dbobji-cpp-7319-enot...
Thank You!
Jonathan Focht
