Custom Structure Not Showing Up in Model Space
I have created a custom structure object using Part Builder. The part validates, the test report shows no errors, and inside part builder I can change the various parameter values and the 3d object (modifier) acts correctly. However, whenever I add that part to a pipe network there is no 3d model of the part. The part is in the drawing and the structure properties shows all the info, but the actual model of the part is not in the model space.
Here is the part in part builder. The highlighted object is the 3d solid that should be the part showing up in a drawing. I have set the Autolayout Data placement point to the fixed center point of my centerplane where the model is anchored.
Here is the part when placed in a pipe network. No object is shown in the model space, but the object exists in the prospector, pipe catalog, and even the structure properties for it. I put a null structure with the same Standard style to show that it's not a style issue.
What could be going on? It's probably something simple, but I can't find what's causing it to not work.
Windows 11
32GB RAM
