Civil 3D Forum
inserting a block not working
4 REPLIES 4
3641 Views, 4 Replies
When I insert a block, I can see it in preview but when I pick a point it disappears.  I tried changing insbase and insunits but it still doesn't work.  I can't even copy and paste.  It happened before and restarting my computer worked but this time I can't get it to work. Please help!
4 REPLIES 4
Jay_B
You didn't mention if all layers were thawed & on?
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
in reply to: Jay_B
I am haveing a similar problem with vrs 2015. See Post
Dave Z.
yes all layers are thawed and turned on
Pamela K Ayala
Brennan Engineering
561-392-3748 OFFICE
561-601-1278 CELL
jmayo-EE
If you open the block in the block editor, is the block located close the the origin or is it out in space somewhere? If it is not at the origin move it there from the expected base point.
Of course you could also simply zoom to the drawing extents and see if the block has a bad insertion point. If the block is out in space you will need to edit it as described above.
John Mayo
Rail Community
