Importing Overlapping Lines
Justinkmurphy1106
Message 1 of 12
Justinkmurphy1106
I am importing design lines from ArcGIS that are laid ontop of each other.  Is there a way to make the lines either import stacked above each other or a simple way to separate the lines without "moving" or "array" or "offsetting" each individual line?
Replies (11)
Message 2 of 12
RobertoJJoaquin
Hi, i understood do you mean with separated, in different files ?? so these lines are in different layers, when you export o load in arcgis you have a colum with layer and you can classified
Leave a like! If you found this helpful.
If your query has been solved, mark it as a solution. This will help other people find it easily later.
¡Deja un like! Si te fue útil lo indicado.
Si tu Consulta ha sido solucionada, marca como solución' esto ayudara a otras personas a encontrarla fácilmente a Posterior.
Message 3 of 12
Justinkmurphy1106
I am trying to have them separated when importing them into Autocad. So I
do not have to manually move hundreds of lines to be 1-5' offset from each
other.
Message 4 of 12
fcernst
Is this a User logic issue ? Use MAPCLEAN or OVERKILL to remove Duplicates.
r
Fred Ernst, PE
C3D 2027
Ernst Engineering
www.ernstengineering.com
Message 5 of 12
Justinkmurphy1106
Do not want to overkill and delete the lines. They are all specific design
details but are overlaid ontop of each other for ArcGIS design.
Message 6 of 12
RobertoJJoaquin
But these elements are in different layers, or do they all have the same layer? To what format are you thinking of exporting or is it just a DWG file that will be used to import into ARCGIS (what software)?
Message 7 of 12
fcernst
Then…I would suggest Filter ..by Fields ..out with Data Export in ArcGIS Pro …into two separate Shapefiles..
Fred Ernst, PE
C3D 2027
Ernst Engineering
Message 8 of 12
fcernst
Maybe you could do a Qselect by Properties in CAD.. and put on a different layer
Fred Ernst, PE
C3D 2027
Ernst Engineering
Message 9 of 12
fcernst
Same in Map.. maybe select/query by an Attribute
Fred Ernst, PE
C3D 2027
Ernst Engineering
Message 10 of 12
Pointdump
Hi Justin,
Having a hard time picturing this. What do you mean by "laid ontop of each other"? The same line at different elevations? Are these shapefile lines or DWG/DXF? A picture of what you've got would help to see what you see.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 11 of 12
Justinkmurphy1106
This is an ArcGIS shapefile being imported into AutoCAD Civil 3D. They are
on separate layers as well.
Message 12 of 12
Pointdump
Justin,
You can MAPIMPORT the lines onto different layers based on OD(Object Data).
Can you post one of your shapefiles?
Dave
Dave Stoll
Las Vegas, Nevada
