SSM Page setup override
Joe-Bouza
Mentor Mentor
Joe-Bouza
In the olden days I could call up a PSO via SSM. It seems now I can call it up but if it isnt set in the sheet file it ignore it.
What is the sense if I have to import and set current for every file.
I must have missed something
Joe Bouza
brian.strandberg
Are you printing to PDF (I usually am)?  Have you looked at the Sheet Set PDF publish options?
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
Joe-Bouza
Hi Brian, yes and yes. But that has nothing to do with a page setup override
the issue is, we my from time to time recycle layout tabs from older jobs that may have been setup with an older plotter. I typically have a project specific dwt that I set the page set up parameters among other things point to it in SSM and batch plot
the older layouts don't seem to honor the override. once I import it into these older layouts it works. It just seems to defy the logic of an override
I know it work flawlessly in the past
Joe Bouza
rl_jackson
I've had this same problem; sorry I don't have a solution as I had to go through all the sheets and set it.
Rick Jackson
Survey CAD Technician VI
Joe-Bouza
Kind of maddening
Joe Bouza
