Hello. Today I tried importing mr .SID and a .tiff file. I am working in a county coordinate system. The MR. SID file is located in NAD UTM Zone 15 N. At the very end of the .prj file the description also says Meter. When I import this file it does not come in correctly. What are the proper steps for importing .sid?
Similar situation with a geotiff. Geotiff was in a known county coordinate system, but the drawing I received from another firm was in a different coordinate system. How do I import geotiff into a different coordinate system?
Thank you
TG
Solved by ChicagoLooper. Go to Solution.
Hi Todd,
If the image is in a different coordinate system than your drawing, you'll need to use Raster Tools IINSERT or Map Tools MAPCONNECT.
MAPIINSERT won't transform an image.
Dave
Dave Stoll
Las Vegas, Nevada
The Raster tool did not work either (IINSERT). I have not tried mapconnect. Am I able to plot the image using the mapconnect? I am not familiar with the mapconnect.
Thanks!
TG
Todd,
What didn't work with IINSERT? Screen shots please. Even better, post the MrSID and GeoTiff. If they're large, you might need to use WeTransfer or OneDrive, etc.
Dave
Dave Stoll
Las Vegas, Nevada
MapConnect is the easiest and probably the most misunderstood. Yes, you can print using MapConnect and if you can't then it's due to user error.
You can also use MAPIINSERT command. Or from the ribbon go to Planning & Analysis workspace>>Insert tab>>Import panel>>Image Icon.
In the Insert Image window, change 'Files of Type' to MrSid (*sid) then Browse to and select your image. Click OPEN. Be sure to check the Modify box so you can transform from UTM projection to State Plane Projection.
The next window has two tabs. Make your selections using the images below as your guide.
Until you clip a viewport, from my experience.
Rick Jackson
Survey CAD Technician VI
In addition to what the others have stated, be sure to set your AutoCAD units to the proper foot. Remember, Autodesk added US Survey Foot as a unit to core AutoCAD, so the old Foot is now international foot. Not sure why Autodesk doesn't have C3D's units automatically match/change the ACAD unit, but it's something I've been noticing lately where companies aren't realizing that core ACAD added US Survey foot as a unit.
Thank you for the detailed info. The data connect worked. However that method really slowed down the file. Every time I panned or moved I get the status bar and executing query popping up.
The IINSERT did not work for the geotiff. The MAPIINSERT did work for the geotiff as long as I did not have the modify correlation selected. If I modified the correlation then the geotiff never imported correctly.
Thanks for your help.
TG
If panning and zoooming is slowing you down when using a Data Connection then it means two things:
To reduce the size of the image and gain better modelspace mobility, zoom-in on your image (focus on your site) so the important part of the image fills up modelspace. Make sure the area of coverage is enough (or slightly more than enough) to fill up your viewport, otherwise you'll have a 'blank' area when you plot. Next, in the Map Task Pane, right-click your image and select Resample Raster from the shortcut menu. Zoom-out and you'll notice the parts of the image that was offscreen will not be displayed, therefore your panning and zooming will no longer have to regen such a big image--the regen is what slows you down. If you wish to return the image to its original size, zoom-out, way out, then right-click and resample again.
