Civil 3D Forum
Importing/Exporting Layer Filters
5 REPLIES 5
cwasemann
537 Views, 5 Replies
I use Civil 3D 2022 and I would like to import a saved layer filter to my drawing. Unfortunately, my company will not allow me to add this to my template.
Can someone walk me through the steps.
CSW
Tags (1)
Labels (1)
5 REPLIES 5
VincentSheehan
in reply to: cwasemann
Will Load Filter Groups work for you?
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
cwasemann
I do not have that icon.  Let me check my options, unless you know where it is or how to add it.
cwr-pae
LAYERLOADFILTERTREE to load layer filter from Keyboard
LAYERSAVEFILTERTREE to save layer filter from Keyboard
You can add the buttons into the layer manager - see this article posted by Autodesk.
It does require modifying the registry in the local machine area which you company may not allow.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Load-Layer-Option-...
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
TerryDotson
Rail Community
