Importig .rvt file into Civil3d
mateusz.dunaj
mateusz.dunaj
How  I can import revit file into  Civil3d ?
My revit file cannot be exported to .adsk    and when i  export to IFc it's loosing coordinate system.
In  civil  2019  i  saw that we cannot import FBX file....
I attach  .rvt file, maeybe someone knot how solve this problem.
ToddRogers-WPM
Export it out of Revit as a DWG file. Then follow directions for the shared reference point. See below...
https://knowledge.autodesk.com/search-result/caas/simplecontent/content/start-coordinating-these-rev...
Todd Rogers
Civil Administration at Walter P Moore
samir_rezk
I would export the Revit file to an .nwc file (Navisworks)
https://knowledge.autodesk.com/support/navisworks-products/learn-explore/caas/CloudHelp/cloudhelp/2019...
Then you can simply xref it in AutoCAD. In the xref palette, choose coordination model!
This way you’ll get better performance in Civil 3d and a smaller file size, you will still need to take a look at @ToddRogers-WPM link to get the Revit model geo coordinated.
hope this helps,
Samir Rezk
Technical Support Specialist
