Civil 3D Forum
Import Latitude-Longitude coordinates as points
13 REPLIES 13
Message 1 of 14
demus72
2750 Views, 13 Replies
I am certain I am beating a dead horse, I apologize.
I have a list of 23 latitude longitude coordinates that were collected out in the field. I am desperately trying to import them from a comma delimited txt file as points into my state plane drawing. I've set up a point file format with Coordinate zone transform checked and entered the Zone. I used Point Number, Latitude, Longitude, and full description for columns. I've loaded the txt file and parsed it, it appears to work fine.
In my state plane drawing, I import points from file, select my txt file, it automatically selects the point file format I created, I checked Do coordinate transformation if possible and hit ok. It creates points but nowhere near my location. Do I not need to specify a Coordinate zone transformation in the point file format? Do I not need to check Do coordinate transformation if possible? I'm sure I've tried both in my panic but just can't get them to come in in the correct location.
Thanks for you help.
13 REPLIES 13
Message 2 of 14
Pointdump
in reply to: demus72
N,
Post your text file of lats and longs. There's a few subtleties with geographic coords.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 3 of 14
demus72
in reply to: Pointdump
Attached is my txt file.
Thank you.
Message 4 of 14
Pointdump
N,
OK, so it looks like your coordinates are in Degrees and Decimal Minutes. That degree symbol is the fly-in-the-ointment. Replace that with a comma and then set up your Point File Format thusly:
Drawing with "P_DM_DM_Desc" Point File Format attached. Don't forget to do the "transform if possible" on import.
Dave
Dave Stoll
Las Vegas, Nevada
Message 5 of 14
Pointdump
N,
I just noticed something. You'll want to change the Longitude Degrees to minus, otherwise you'll place those points in Mongolia.
Dave
Dave Stoll
Las Vegas, Nevada
Message 6 of 14
Pointdump
N,
I imported your points into a Montana State Plane Coordinate System (HARN/MT.MTIF) and those GPS'ed points seem to follow the Concrete Ditch.
Drawing attached.
Dave
Dave Stoll
Las Vegas, Nevada
Message 7 of 14
demus72
Dave,
Thank you very much! I modified my txt file and my point file format following your proven recommendations, then imported the point and JACKPOT!
I tried just about every combination possible but no matter what I did, I couldn't make it work.
Thanks again for taking the time to share your knowledge, very much appreciated!
Nick
Message 8 of 14
CADmgrMike
I'm having the same issue. I need to import some Lat Long points. I created a new file format, but the first column won't parse correctly. I attached a sample csv file.
Mike Porter
https://provostandpritchard.com/
Message 9 of 14
Pointdump
in reply to: CADmgrMike
Mike,
Your CSV file is in UTF-8 format. In Excel, save as regular plain old CSV format. Then all is good.
Dave
Dave Stoll
Las Vegas, Nevada
Message 10 of 14
Pointdump
Mike,
Or option #2 would be to use Notepad to save as a .txt file in ANSI format:
Dave
Dave Stoll
Las Vegas, Nevada
Message 11 of 14
CADmgrMike
@Pointdump  Thanks. I didn't catch that.
Mike Porter
Message 12 of 14
CADmgrMike
@Pointdump , ok. I saved as txt file and got C3D to recognize the file, but the point file format still giving me the message that it doesn't match.
What am I missing? (test file attached)
Mike Porter
Message 13 of 14
Pointdump
Mike,
In your Point File Format use DECDEG Latitude and DECDEG Longitude. Latitude and Longitude are DD.MMSSssss format.PLLZD_1.png
Dave
Dave Stoll
Las Vegas, Nevada
Message 14 of 14
CADmgrMike
@Pointdump  U da man! Thanks. 🙂
Mike Porter
Rail Community
