- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am certain I am beating a dead horse, I apologize.
I have a list of 23 latitude longitude coordinates that were collected out in the field. I am desperately trying to import them from a comma delimited txt file as points into my state plane drawing. I've set up a point file format with Coordinate zone transform checked and entered the Zone. I used Point Number, Latitude, Longitude, and full description for columns. I've loaded the txt file and parsed it, it appears to work fine.
In my state plane drawing, I import points from file, select my txt file, it automatically selects the point file format I created, I checked Do coordinate transformation if possible and hit ok. It creates points but nowhere near my location. Do I not need to specify a Coordinate zone transformation in the point file format? Do I not need to check Do coordinate transformation if possible? I'm sure I've tried both in my panic but just can't get them to come in in the correct location.
Thanks for you help.
