Civil 3D Forum
Import Asc file
13 REPLIES 13
Message 1 of 14
rimutaka
50431 Views, 13 Replies
Import Asc file
I have bathynetric data with file extension ASC.
How do I open it with Autocad civil 3D?
Fyi, I found some posts similarly with my question but don't help much.
Thanks in advance
13 REPLIES 13
Message 2 of 14
MikeEvansUK
in reply to: rimutaka
Not sure what data the file contains but have you tried creating a point cloud? Lidar data is usually ASCII format and you can import that using point clouds.
You may be able to import that way, create a surface and export points as XYZ if neesesary otherwise you'll need to convert the file to an .XYZ file (ASCII to XYZ?)
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Message 3 of 14
AllenJessup
Post a couple of lines from the file so we can see what format it's in.
Allen
Allen Jessup
CAD Manager - Designer
Message 4 of 14
TerryDotson
It's likely a ESRI ASCII Surface.  If you drag/drop it into a notepad the first lines should look like this:
ncols 200
nrows 200
xllcorner 119000.00
yllcorner 158000.00
cellsize 5.00
nodata_value -999999
Try creating a surface in Civil3D, then under the Definition, DEM Files, choose Add, the use the button in the upper right.  Under the "Files of Type" you'll find the format.
Message 5 of 14
rimutaka
in reply to: TerryDotson
Thank you for all replies.
Terry, I tried to follow your suggestion but I still could not open it in civil 3D.
Attched is the bathymetric file after converting to TXT file (it's failed when i sent in ASC format).
FYI, I am using Autocad Civil 3D 2011.
Message 6 of 14
Jeff_M
Your file imported just fine for me. Followed Terry's instructions exactly, even with the txt extension.
Jeff_M, also a frequent Swamper
Message 7 of 14
rimutaka
Hi Jeff,
Finally it works!!Smiley Happy
Regards
Message 8 of 14
rimutaka
While this thread still open, I have another question.
I have a coastline data in DAT extension. Can I import it in civil 3D? If yes, how?
Thanks in advance.
Message 9 of 14
TerryDotson
The DAT extension is used by many applications and isn't a standardized format that I'm aware of.  Post the file as an attachment and we will see if we can make any recommendations.
Message 10 of 14
rimutaka
Hi Terry,
Attached is partly of the original file after converting it to text format.
I can't send an original file as it is too large.
Hopefully it helps
Regards
Message 11 of 14
TerryDotson
That is an ESRI GEN file and it appears to be in Lat/Long for islands of Maluku.  Here are the options as I see them.
A) Do some fairly significant editing in an ASCII Editor, the first step will take the most time.
  1. Change each sequential ID number to PLINE
  2. Find/Replace single space to nothing.
  3. Find/Replace END to nothing.
  4. Save with .SCR extension.
  5. Draw with AutoCAD's SCRIPT command.
B) If this is a one time problem, zip the file and email it to me at dotson [at] dotsoft [dot] com, I will send you a DWG file.
C) If this is regular occurance, consider acquiring MapWorks Base, which will read this and numerous other formats.
Message 12 of 14
I have an *.asc file with 107,000,000 points in teh spacing of 1m by 1m
is there a way to create surface using add DEM data but only sampling every 10th point
Rahul
Message 13 of 14
Kathy-CAD
Hi, even when this is a very old discussion, it is still open..
I use AutoCAD Map 3D, but I think the FDO Connecting Tools are the same in Civil..
You can insert *.asc over FDO connecting "Raster image and Surface".
After connecting and insert, you can change Style gray, color, theme..
Message 14 of 14
in reply to: Kathy-CAD
Q. How can I open an ".ASC" file?
Answer
Use Notepad or TextPad on Windows; TextEdit on Mac OS.
An ASC file is an armored ASCII file used by Pretty Good Privacy (PGP), an encryption program used for secure communication. It contains a digitally signed message and may store plain-text written information, as well as binary information encoded as text.
thank you Google...
good luck
nonbeard 13
Rail Community
