Different values of X,Y,Z between "Point ID"and "Point Properties" for a point
Hello
I plot a points to AutocadCivil3d 2017 by northing/easting/elevation, when i click id and select the point it shows the true coordinates that i previously entered (X,Y) but with Z=0. but when i go to the properties of the point it displays another coordinates ( Different X & Y) but with true value of Z
Hi, The problem is the plotted values at the point label? Are you using World UCS? Check in the label style if you are showing the coordinates or the grid coordinates.
yes am using world ucs and there is even no label, that didn't solve the problem
Jeff_M
Is your PointStyle set to "Flatten to Elevation"?
Jeff_M, also a frequent Swamper
Can you uoload an image of your issue? It will make easier to understand.
