Image frame issues
Image frame issues
ericL4ECC
Image frame issues
ericL4ECC
I've read through all of the previous posts about image frame issues and haven't been able to resolve my issue. I have some aerial images that keep showing inconsistent white borders when plotted. Sometimes thicker, sometimes thin, sometimes non existent. I've played around with IMAGEFRAME and FRAME settings endlessly with no luck. CAD file, images and example pdf can be downloaded at the link below (hopefully that's okay as there are more than 3 attachments). Any insight would be greatly appreciated! Thanks.
https://www.dropbox.com/scl/fo/mueohw8kw0r0qq58mcrws/AP60sra0B3lJOcS73AtV49s?rlkey=6nve51hudawk8pwzt...
ianjchap
hI @ericL4ECC,
There are other settings that will help depending on the image type. Additionally to what you've mentioned there's DWFFRAME, PDFFRAME, DGNFRAME, XCLIPFRAME, and WIPEOUTFRAME.
If it's a DWF or PDF file then these may be more relevant, more info here:-
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-29BD70BB-07BF-41A2-8C2F-AD41C9402486
Ian Chapman
If you found this post useful, please Like the post.
If this post helped you successfully solve your problem, then click on the ACCEPT SOLUTION button.
AllenJessup
You might try TFrames.
Allen Jessup
CAD Manager - Designer
tcorey
I was going to suggest using Raster Design, part of your Autodesk Subscription, to merge the images into one, eliminating the seams between them. Alas, your images cannot be edited due to having different x and y scales.
type iimerge (yes, two I's) or use the ribbon.
I inserted a couple of your images into a blank drawing and was able to merge them.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
AllenJessup
@tcorey I wonder if the difference in X - Y Scaling had any affect on the inability to hide the frames. TFrames made them less visible but didn't completely eliminate them.
Allen Jessup
ericL4ECC
Interesting that the images would have different scales, they were all sourced from the same place at the same time. Will try this out. Thank you!
Pointdump
Hi Eric,
Add all the images to your drawing with MAPCONNECT and click "Combine into one layer".
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
