We're trying to share our design to our Revit folks by exporting our pipe network into a IFC format.
We're all using Civil 3D 2023 with the IFC 4.3 Update 2.
As soon as we try to link the IFC in Revit or Naviswork the file is "Unable to open".
When we redo the same process with Civil 3D 2024 and the IFC 4.3 add-on on 2024 the file is recognizable.
Anyone has a clue how to make this work or have experienced this ?
Solved by cyberflow. Go to Solution.
Hi @paulo_santoso !
Unfortunatly our production version is 2023 and cannot go by 2024 or 2025.
Hi @paulo_santoso
I finally found out why the file wasnt openable with Revit.
In the "IfcInfraConguration.json" file (That's can be generated with the tool), the file version of IFC is exported as "IFC4X3_ADD2" by default.
We need to edit the config to change the IFCVERSION to "IFC4X3" that is supported with revit :
Hope this helps anyone in the future
