Civil 3D Forum
ID command doesn't match point label NE's
4 REPLIES 4
byoderBLGP7
205 Views, 4 Replies
Point coordinates given from the ID command to not match the coordinates shown on my point labels.  When I create a line at 0,0,0 and then put a point on that end, the point label shows coordinates of roughly N:134, E:161.  I am working in 2D, so there is no Z elevation.   UCS is set at 0,0,0.
Labels (2)
4 REPLIES 4
Can you share a sample drawing?  Thanks.
I spend time on this forum because I enjoy Civil 3d and getting your likes.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Civil 3d to Street View: https://youtu.be/8Ima00-vLQA
Vote for My Idea:
https://forums.autodesk.com/t5/civil-3d-ideas/favorite-coordinate-zones/idi-p/12790928
No problem!  Thank you...
When I open the drawing, I can see its in an unnamed (non-world) ucs.
Once I change the ucs to world, the coordinates check out.
Vote for My Idea:
byoderBLGP7
in reply to: byoderBLGP7
Thank you Brian, that resolved the issue!  I'm not sure how that got messed up.
Rail Community
