Point coordinates given from the ID command to not match the coordinates shown on my point labels. When I create a line at 0,0,0 and then put a point on that end, the point label shows coordinates of roughly N:134, E:161. I am working in 2D, so there is no Z elevation. UCS is set at 0,0,0.
Solved by byoderBLGP7. Go to Solution.
Can you share a sample drawing? Thanks.
When I open the drawing, I can see its in an unnamed (non-world) ucs.
Once I change the ucs to world, the coordinates check out.
Thank you Brian, that resolved the issue! I'm not sure how that got messed up.
