I work for a company where we have "Auto Desk University" thru Degreed. I have been using Autocad since 1986. I took training classes yrs ago for DCA, Benchmark, Soft Desk, & LDD. I've never had any C3D courses. I'm looking for refresher courses for 2018 C3D that can take me back thru; creating & editing points & point files, surfaces, alignments, profiles, & sections, & grading. I've had people "tutor" me on these but on different versions of C3D so I have gaps in my knowledge & abilities. Does Autodesk have any classes/courses for users like me? If yes, what are their titles? Are they available thru Degreed? Or directly from Autodesk?... I've tried going thru the Autodesk "Contact Support" but I get to a dead-end. Does anyone have any suggestions?
Solved by AllenJessup. Go to Solution.
THIS is for 2019 but will be the same for 2018.
You could sign up for Autodesk University 2021. After you sign up you will have access to previous years classes.
The procedures you're interested in haven't changed much from the past. Many have been improved but not changed in concept. DCA-Softdesk-LDD form some of the background. But everything has changed in Civil 3D. The most important concept if Dynamic Linking. So if you change the Alignment. You won't have to rerun the Profile.
Come back to the Forum if you need help along the way.
Allen Jessup
CAD Manager - Designer
