I have a file with 3d faces that I want to create a surface from. I do the usual drawing object --> 3D faces --> maintain edges routine. A surface is created but there are holes, as if some of the 3D faces have been omitted -see picture.
Things I've tried:
- using only faces from one lane of the road, works fine --> adding the next lane, not fine
- making sure that no vertical faces are in the selection, no difference.
Any suggestions on what the problem might be?
I have attached a screenshot of my attempt to create a surface and the dwg with the 3D faces.
thanks
Johan
Solved by AllenJessup. Go to Solution.
Some of the faces are longer than your Maximum Triangle Length. Either turn that off or increase the maximum length.
Allen Jessup
CAD Manager - Designer
You're welcome.
Allen Jessup
