Hydraflow Storm Sewers - Rational Equation
jrennickUQAYD
jrennickUQAYD
Community Visitor
Community Visitor
I'm looking for some insight on how Storm Sewers handles the frequency factor (Kr in SS) in the Rational Equation.  Per the user manual, Kr = 1:
However, some drainage manuals specify that the frequency factor varies based on the storm event:
For a long time, my workflow has been to create multiple SS files for the different storm events that I want to analyze, with the C-value of each drainage area adjusted based on the required frequency factor.  However, this gets tedious, especially for large networks.
My question is this:  Does Storm Sewers adjust the frequency factor for different storm events?
matt_anderson_pe
Kr is not Ki.   Kr is a unit conversion factor.  Its not exposed, so you cant change it.
Ki is a multiplier for rainfall.  It probably would be just as easy simply increase your rainfall values by 10, 20 or 25%.
Matthew Anderson, PE
Inundar, LLC
https://wettingthewhetstone.substack.com
lim.wendy
Hi Jacob,
Thank you for submitting your question in our discussion forums.
I see you are visiting as a new member of the Civil 3D forum. Welcome to the Autodesk Community!
Thanks for reaching out to the forum. Have you had a chance to look over Matt's suggestions?
Let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
fcernst
No just can’t hit the Q like that... because you have to make sure C x Cf <= 1
Fred Ernst, PE
C3D 2026
Ernst Engineering
www.ernstengineering.com
matt_anderson_pe
i.e., it works ok if C < 0.8.   It's a manual validation.
Inundar, LLC
