Civil 3D Forum
Howto get Civil3D to plot color bands for Surface Slope Analysis?
2 REPLIES 2
camptech
149 Views, 2 Replies
My Googling and searching the C3D forum have proven fruitless.  I figured out how to create a Surface Slope Analysis displaying all areas of my drawing in five bands:  0-10% (cyan), 10-20% (light green), 20-30% (dark green), 30-33% (yellow), and > 33% (specifically 33-100%; red).
The colors display in model model space and paperspace.  I was able to stumble my way through inserting a Slope Table.  But when I try to create a PDF with the colors to send to the builder client to highlight the high slope problem areas (> 33%)... all I get is a black and white plot, although the Slope Table colors plot fine.
This is very frustrating.
Here is the Surface Properties popup window:
Here is a screen capture of a paperspace window:
Surface Slopes - color banding - Paperspace - Screenshot 2024-07-03 115224.png
But when I plot and create a PDF, the PDF has no color on the surface, although the color swatches are correctly shown in the Slope Table.  Similarly, if I click on [ Preview ] in the Plot menu window, the preview shows no colors where the surface is, although the Slope Table shows the color swatches correctly.
I'm thinking there's got to be a quick and easy way to do this (that is just non-obvious)... or maybe not.  Who knows with C3D.
Here is what a Plot Preview looks like (screen grab):
TIA for any help.
2 REPLIES 2
user181
in reply to: camptech
Edit the surface style and on the Display tab make sure the Slopes component is assigned a layer that plots.
camptech
in reply to: user181
Thank you!
Will have to chock this one up as PEBKAC.
I had poked around inside the Edit Surface Style Dialogue... but I had failed to notice the scrollbar on the far right and totally missed the *Slopes* entry. Sure enough, that layer was one I had created, and it was set to NOT plot. Changing that layer to plot and creating a PDF with surface colored to slope values worked without any further issues.
Thanks again.
Rail Community
