I agree with @Pointdump in post 9: "Reconsider using the original point cloud data. Contours are not the best data to build a surface with".
I think Civil 3D users need accurate surface models and good-looking contours.
Surfaces model the available "ground" data.
Contours are representations of the surface model.
The imported 3DSurvey contours are a representation of the 3DSurvey surface model.
A surface modeled from the 3DSurvey contours is a representation of the contours, not the underlying source surface.
Specifically, contour-based surfaces do not accurately represent ridges and valleys in areas where contours double back on themselves. This is more evident in flat areas. This is the model (drawing) that you provided. The surface is stylized with 0.25' contours. The cyan areas are much flatter than expected.
Here is a detailed view of the eastern area.
They would be different if you were to hand draw the intermediate contours.
I suggest that they would be more accurate.
If I were creating a surface from surveyed points, I would include break lines to ensure that ridges and valleys were modeled correctly.
The point cloud process says, "we don't need no stinking break lines."
This is correct because you have a fractillion points available and more than enough information to model the surface. When you extract contours from this model, you get an accurate representation of the contour paths but no information on the areas between contour lines.
Does it matter? Is it good enough? I am a great fan of good enough.
Sometimes it is good enough; sometimes, it is not.
Here are profiles along the ridges and valleys (washes.)
The ridgeline inaccuracies are probably acceptable for manually determining catchments but are problematic when examining overtopping conditions.
The valley flowlines are problematic. Feature lines draped on the surface do not show reasonably accurate slopes. Water drops stop at flat areas that sometimes occur. Surface-based cross-sections are not accurate.
I am indeed capable of estimating and scaling, and interpolating. I have done it for decades. With a point cloud level of detail, I should not still have to guesstimate.
I am unsure what it is, but there is something better than contour-based surface modeling.
End of rant!
Christopher Stevens
