Hi Team,
I have a Sample Line Group(SLG) and a X Section View Group based on it.
The station/chainage range of the SLG was, say, 500 ~ 1500. Now I am being asked to change it to, say, 0~1000.
It is to say, I am extending it from 500~0, and cutting off the back part of 1000~1500.
I successfully updated the SLG to 0~1000 after a couple tries.
However, the X Section View Group only updated for shortening 1000~1500, and refuse to add the part of newly extended 0~500.
Means, it is 500~1000 now instead of 0~1000.
I did some research and found the post of below and it did not work for me.
Adding a Cross section to a Section View Group doesn't work - Autodesk Community - Civil 3D
I did create a new X section view group and had to reset up all the labels, re-projecting all the elements. Such a pain.
So I am seeking a way to avoid that for the future.
Very much appreciate for any ideas or suggestions, thank you!
Solved by MSchille-1994. Go to Solution.
you could take the 500 cross section and copy it however many time you need. Doing this will copy the sample line on top of itself, but you can select it, (500 (1)), and change the station to whatever value you want. I do this all the time. If you need 5 additional ones, copy the sample line nearest to where you need more and copy it 5 times, then just select each one and change the station value. Then go over to your cross section views and select one of them and click on "Update View Group" on the ribbon.
Thank you @MSchille-1994 for yor help.
Manually adding sample line seems suitable for samll amount.
Hoep we have a more convenient way for adjusting it as well as the section views.
Hi @MSchille-1994 , sorry I didn't read your solution carefully. I thought you talked about copying sample lines.
I am trying now and let you know if it works for me.
Things I found:
Thank you!
OK it works, however, do we have a faster way to change the staion value of the new sample lines?
Currently I select them from Toolspace, then change the value in their properties 1 by 1.
Every time it works quite a while to reflect the changes...
if you have 500 sample line, it would be quite a time consuming.
Glad this worked for you. Yeah, usually I get my sample lines about 98% correct when I initially create the sample line group, and then I usually have to add a few as the project progresses on. If something majorly changes, it usually warrants a new sample line group anyways, so I just create a new group.
Thank you @MSchille-1994 , it's a great idea to re do the sample line group. I usually do so until the work recently that I was asked to keep everything of section view grop (style, bands, projections) as it was, so it's some work to re created all this and keep them look like the same as before.
That is the reason why I try to modify the sample lines instead of re create it.
Again, thank you for your great idea and time!
Hi @MSchille-1994 , just let you know I am trying to use your diea today for the extension of my sample lines.
unfortuntely I am finding the newly added section views do NOT apply the existing styles of other section view like below show.
Blue ones are existing and Red ones are newly added. You can see clearly they are different.
New ones remain C3D default style which made adding sample line meaningless.
Any way your idea is great if we don't set any specific style on the section views.
Very very dissapointed with C3D, it can be better for user to edit existing elements not repeating everything.
Yes, Match properties does work on many Civil 3D objects for matching styles, I use it all the time.
As for adding sample lines to an existing group, you should be able to use the AutoCAD Copy command, select a sample line, pick a basepoint, pick a second base point, and it waill copy that sample line on top of itself. Thus, if you have a sample line with a label of "5+25.00", there will be another sample line on top of it labeled "5+25.00 (1)". Then just select the sample line and grip edit it to it's new location.
Is that not working for you? Can you send me your drawing? mschille@fmgengineering.com
According to my experience recently, I suggest you to add Xsec views by copy(CAD command) sample line if you have less than 10 sample lines to be added.
However, if you have more than 10 sample line to be added, I strongly suggest you to re do sample lines and re generate Xsec View group. It's far far faster I promise you.
A tip is save style set for later use.
