Here is a screencast showing the technique. It is my first attempt using the forum screencast software so it's pretty crude. There will be some awkward steps in the workflow when I fumbled for tools.
The technique is the sameI recommended earlier. You create a featureline around the caisson and apply the daylight grading to it.
1. Set grading parameters to: Site=pedraplen. Grading Group =Pedra1. Target surface=SB+Banqueta+cajones.
2. Start with a rectangular featureline around the caisson and set it to elevation 2.00.
3. Add a vertex at the approx. mid-point of the south (downhill) side of the rectangle and set it to the elev. -16.00 (=caisson base elevation)
4. Use the Insert High/Low elevation point tool in the grading tools to create elevation points that are 66.7% slope between the north corners of the caisson along the south face. For the input parameters use -66.7% back slope and 0% ahead slope.
5. Apply a grading to the resulting featureline at 1.5 slope to the target surface.
6. Add an infill for the gap between the Caisson and the slope grading on the uphill side.
Inthe video I start with a rectangle that includes the flat area on the north side of the caisson and I close the area with a featureline and add an infull. Other than that the procedure is the same. I realize thiis is hard to follow but it the bast I can do given the time I have spent on it. I hope you can make sense of it from the video.
http://autode.sk/1NU4KD6
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
