Civil 3D Forum
How to move position of command line?
8 REPLIES 8
Message 1 of 9
rimutaka
17512 Views, 8 Replies
I used to work with position of command line at the bottom of the screen, but recently it moved to the upper left corner of screen.
I have followed suggestions from threads in forum but the result is same, command line position didn't change.
Can some one provide me information how to move command line to the bottom of the screen?
Thank you in advance.
8 REPLIES 8
Message 2 of 9
Pointdump
in reply to: rimutaka
R,
You should be able to grab the grey bar to the left and move it anywhere you want. Also, click the wrench for options on customizing the command line.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 3 of 9
mathewkol
Hold down the ctrl button before you grab it if it doesn't move just by grabbing it.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 4 of 9
mathewkol
I guess I should have said hol ctrl AND drag at the same time. Look un palette locking in Help.
Matt Kolberg
Message 5 of 9
rimutaka
in reply to: Pointdump
Thank you for prompt reply.
I have followed all suggestions but my command line position still same in the upper left corner of my screen.
Below are briefly explanations about the command line:
1. It only appears on screen when I type something
2. No "wrench" icon
Message 6 of 9
Pointdump
R,
Can you post a Screen Shot or Sample Drawing?
Dave
Dave Stoll
Las Vegas, Nevada
Message 7 of 9
ToddRogers-WPM
I wrote a blog on something similar to this.  This will walk you through the steps to fix this from the CUI...
http://civil3dj.wordpress.com/2012/04/27/my-command-line-is-missing/
Todd Rogers
Message 8 of 9
I had same problem, but i could solve it by this link. Please follow this: https://civil3dj.wordpress.com/2012/04/27/my-command-line-is-missing/
Message 9 of 9
worked, thanks
Rail Community
