I’m working on a road widening project and have a few questions regarding the assemblies. These have probably been asked before but I could not find them when searching.
I would prefer not to “hand draw” the cross sections. I have also attached images of my current cross section and an image of how the cross sections should look (of existing and proposed pavements).
Any suggestions are most welcome.
C3D 2016, SP3
Win10 Pro
Regarding showing existing pavement, has this been surveyed and a surface created? If so, modify the surface style: display tab, set view direction to Section. Set the linetype you want to see in section view. You might also need to adjust the LTSCALE here.
If you are trying to apply a linetype to subassemblies, you need to do this by modifying the Link style in the Code Set Styles.
To get the area fill you desire, apply a Shape style within the Code Set Styles.
As far as tapering those paved sections, the subassy you're using does not taper, it only lets different pavings have different widths. Try ShoulderMultiLayerVaryingWidth. These layers will taper.
