How to fade a xref when exporting to DWF
ines_forte_d_almeida
I know I can use the option to use transparecy when plotting. But how can i do it when I export sheets to dwf? Even if I put a 90 transparecy in the xref layers or use XDWFADE to the maximum, the dwf file ends up with all the layers turned in their maximum.
pendean
Community Legend
Community Legend
PLOT command (to DWF) has a check box for transparency not easily found in "export", give it a try.
When I export to DWF this is the window I get. I can't find anything related to the transparency.
pendean
Community Legend
Community Legend
PLOT, never EXPORT, see the first sentence in your first post, you state you know how to do it.
Sorry.. I failed explaining my problem, but thank you for your help, using the Export I have a transparency check.
