Civil 3D Forum
How to extract surface boundary AND retain ALL ELEVATIONS
9 REPLIES 9
Message 1 of 10
sfreemancad
855 Views, 9 Replies
I know you can select the surface and extract the boundary or contour data, the issue im having is that when i extract the boundary the elevations along the boundary are generalized to one number and its not even the high or low point its some sort of average... as I am making a grading plan for a ramp, and have a surface for the ramp, i need to retain all the correct elevations in order to produce an accurate grading plan. PLEASE HELP!!!
9 REPLIES 9
Message 2 of 10
user181
in reply to: sfreemancad
Hi @sfreemancad  After extracting it you could use the _AeccFeatureElevsFromSurf  command and add elevations from the surface to it. The command is also located on the Modify tab of the ribbon in the edit elevations panel
Message 3 of 10
sfreemancad
in reply to: user181
I just tried this and it still generalized the elevations along the line, expect now its the lower one being used. I know that its a gradual change up 2'... so each pi should be different and min and max should be expressed. I made a feature line and added elevations from surface and it shows the min and max... maybe thats right
Message 4 of 10
sfreemancad
I have some pic examples of how its not lining up correctly, you can see the ramp surface, in brown, the eg is green, the grade plan is the same brown, you can see the elevation discrepancies
Message 5 of 10
tcorey
Edit the Surface Style.
Go to the Borders tab.
Set Border Display Mode to Use Surface Elevation.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 6 of 10
sfreemancad
in reply to: tcorey
that is already selected, it looks like my ramp surface is floating above EG, and the grade should be between the two..  i attached two pics
Message 7 of 10
_Hathaway
My question would be:  Why are you extracting surface data? Why not just data reference the surface(s)?
Message 8 of 10
sfreemancad
in reply to: _Hathaway
I need the border to make a grading plan...
Message 9 of 10
tcorey
I would need to inspect your drawing...
Tim Corey
Redding, CA
Message 10 of 10
Joe-Bouza
What does extracting data from a surface have to do with making an accurate grading plan?
im accustomed to grading to some original ground usually called existing ground in these parts.
tge we grade to existing to form a proposed grading with the various tools to help match existing accurately *
*accuracy is a function of the data acquired to build EG
Joe Bouza
Rail Community
