How to extract surface boundary AND retain ALL ELEVATIONS
sfreemancad
sfreemancad
I know you can select the surface and extract the boundary or contour data, the issue im having is that when i extract the boundary the elevations along the boundary are generalized to one number and its not even the high or low point its some sort of average... as I am making a grading plan for a ramp, and have a surface for the ramp, i need to retain all the correct elevations in order to produce an accurate grading plan. PLEASE HELP!!!
Replies (9)
user181
Hi @sfreemancad  After extracting it you could use the _AeccFeatureElevsFromSurf  command and add elevations from the surface to it. The command is also located on the Modify tab of the ribbon in the edit elevations panel
sfreemancad
I just tried this and it still generalized the elevations along the line, expect now its the lower one being used. I know that its a gradual change up 2'... so each pi should be different and min and max should be expressed. I made a feature line and added elevations from surface and it shows the min and max... maybe thats right
sfreemancad
I have some pic examples of how its not lining up correctly, you can see the ramp surface, in brown, the eg is green, the grade plan is the same brown, you can see the elevation discrepancies
tcorey
Edit the Surface Style.
Go to the Borders tab.
Set Border Display Mode to Use Surface Elevation.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
sfreemancad
that is already selected, it looks like my ramp surface is floating above EG, and the grade should be between the two..  i attached two pics
_Hathaway
My question would be:  Why are you extracting surface data? Why not just data reference the surface(s)?
sfreemancad
I need the border to make a grading plan...
tcorey
I would need to inspect your drawing...
Tim Corey
Redding, CA
Joe-Bouza
What does extracting data from a surface have to do with making an accurate grading plan?
im accustomed to grading to some original ground usually called existing ground in these parts.
tge we grade to existing to form a proposed grading with the various tools to help match existing accurately *
*accuracy is a function of the data acquired to build EG
Joe Bouza
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
