How to export points into csv format
shashirekha2015
shashirekha2015
I have points in civil 3D it was 2D drawing  but in that points i cannot create surface but i can do manully CSV format manully one by one but its take time and difficult  also.is there any method to export these points into csv or any other format using civil 3D .
neilyj666
I'm not sure what you are asking but you can add AutoCAD points directly to a Civil surface - if they do not have a suitable z value the Civil surface will be not much use though.
You can also use the AutoCAD Data Extraction functionality to export the AutoCAD points to a csv file
An example of the content you have would be useful
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
shashirekha2015
Thanks for your reply,i got the answer for this in the same way.
Thanks.
neilyj666
Please mark as solution if this is now resolved
