How to determine dwg file version now that 2021/2022 changes the file header...
jjohnson_bowman
jjohnson_bowman
This is my last effort to figure out how to determine a dwg file version.  Since we have installed Civil 3D 2022 it seems that the created by/dwg version information in almost every prior version is now irrelevant.  After testing my theory, saving a 2010 dwt/dwg with 2022 for example, changes the file header and data showing that it is current to Civil 3D 2022(see attached files) even though that is not accurate.  This is somewhat disconcerting because that is a specific way of figuring out why some files go corrupt or do not work properly as they should.  In prior builds(i.e. 2018) a file would be saved and would still show "created with autocad 2010" but that is not the case any more.  Has anyone found a way to determine the true origin of a dwt/dwg file after it's been saved forward in 2021/2022??  It definitely makes troubleshooting that much more tedious and rebuilding a template or problem dwg file "just in case" is extremely frustrating although does solve the problem quite a bit of the time.  It also makes it tougher to show users the highly detrimental effects of the "save as".  I know I can't be the only one who is mildly perturbed by this, hence searching for anyone who may be able to shed some light on the issue.
samir.rezk
Autodesk Support
Autodesk Support
Hi @jjohnson_bowman
Once the software saves the file, the file version is upgraded to the default file format chosen in the Option dialog box. The DWG file version hasn't changed since 2018 (AC1032) However, the team may have been saving in an older format if it was configured that way in your 2018 setup:
With that said, the TIME command is a nice way to know how old any file is, and how long the team had been working on it.
Hope this helps,
Samir Rezk
Technical Support Specialist
