How to deselect
How to deselect
nusouthsc
Message 1 of 12
How to deselect
nusouthsc
   Hi all,
I have been using CV3D for about 4 years and I still don't know how to deselect items. I just simply clear my selection and start over. I have read about the Shift+left click, and the "R" command but, cant seem to get either one to work. Can someone give me some clarification?
Thanks!
Josh Ellis
Nu-South Surveying
Anderson, SC
Josh Ellis
Nu-South Surveying
Replies (11)
Message 2 of 12
doni49
Are you talking about selecting a group of objects while no command is active planning to THEN use a command (such as move) on that selection?  There's no remove option there.
What I typically do when I've selected a bunch of things like that and realize that I need to de-select one or more of them is
  1. Escape out of the selection.
  2. Type in SELECT.
  3. Type in P (for previous).
  4. Type in R (for remove).
  5. Pick the item(s) I want to de-select.
  6. Press ENTER.
Now I've got the selection set that I want and can use the command as I had previously planned.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Message 3 of 12
nusouthsc
Yes you're right. That's the situation I'm in. That will work.
Thanks so much for your help!
You all are great.
Josh Ellis
Nu-South Surveying
Anderson, SC
Josh Ellis
Nu-South Surveying
Message 4 of 12
jeff_rivers
Here's what I do when I accidentally select too many things (be it by a window or a crossing window, or just left-clicking).
Hold down the SHIFT key, and while holding, left-click with the cursor pick box over the entity you want to un-select.  You may also hold the SHIFT key and use a window or a crossing window to un-select objects.  Any entity you pick while holding the SHIFT key is removed from your selection set.
Jeffrey Rivers
Win 10 Pro 64-bit, Intel i9 3.7GHz, 64 GB
NVIDIA RTX A4000
C3D 2020 V13.2.89.0
Message 5 of 12
I was accustomed to this deselection method, after using a window selection, it no longer works and I haven't found the fix. This was true for me in 2016 C3D and now 2018 C3D
Message 6 of 12
jeff_rivers
Odd.  I just tried it (C3D 2018 SP1) and it worked fine for me.
Jeffrey Rivers
NVIDIA RTX A4000
C3D 2020 V13.2.89.0
Message 7 of 12
tcorey
Type MAPIOPTIONS. That's the command for Map Image Options.
Go to the General tab, turn off the option to Shift +Left Click Image Select. This will restore your ability to Shift + Left Click to remove objects while building your selection set. One caveat:  You will lose the ability to Shift + Left click to select an image without having to zoom out and select it on an outer edge.
This setting does not affect you if you are not using images.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 8 of 12
MAPOPTIONS didnt work for me but typing in IOPTIONS worked to popup the menu that I needed
Message 9 of 12
tcorey
MAPIOPTIONS, not MAPOPTIONS. Note the I between the P and the O.
Tim Corey
Redding, CA
Message 10 of 12
Take back what I said then, blame it on being a Monday lol
Message 11 of 12
adrianhernandez316
Community Visitor
Community Visitor
I tried going to MAPIOPTIONS and removing the check mark on “Shift+Left Click Image Select,” but it still doesn’t let me deselect by holding shift and left clicking. I do not know how to fix this super useful tool.
Message 12 of 12
tcorey
If there are stacked objects, it won't work. Be sure you turn on SelectionCycling so you know.
Tim Corey
Redding, CA
