Hydraflow Open Channel Cross Sections
Is there a way to import cross-sections created from a sample line group into Hydraflow Express for open channel analysis similar to what can be done for HEC-RAS? These are existing conditions so they are irregular cross-sections that vary the length of the alignment.
Todd_Rogers
Have you installed the River & Flood Analysis module? I think this is what you will want to use if you're doing HEC-RAS. See link below...
http://www.autodesk.com/products/autocad-civil-3d/features/visualization-and-analysis/river-flood-an...
Todd Rogers
Civil Administration at Walter P Moore
jmayo-EE
River and Flood will bring in sections, bridges, culverts, obscured flow areas as well. If you just want sections there is also the Export to Hec Ras button on the Output tab.
John Mayo
PE, CFM, CME
alt="EESignature" width="244" height="22">
