How to delete empty surface
Message 1 of 14
There are some surface built by mistake. They are empty. I could see the name of them in the toolspace, but when I write click their name, there is no DELETE option there.
Because they are empty, I couldn't display them on the screen and delete. So how could I delete them? Thanks
Replies (13)
Message 2 of 14
user181
Hi @Anonymous, If you right click on the surface in prospector and choose SELECT out of the list and they move your crosshairs away from the palette over the drawing area and hit the DEL button on the keyboard it will delete the surface.
Message 3 of 14
Thank you but it doesn't work.
The log says :
Command:
_.erase 1 found
1 was not in current space.
Any other ideas?
Message 4 of 14
user181
You need to be in model space when you do it
Message 5 of 14
I am sure I was in model space...
Message 6 of 14
user181
I would suggest that you please try again from the model tab it would not say 1 is not in current space otherwise. Unless you accidentally created the surface in paper space and I don't think thats possible.
Message 7 of 14
MMcCall402
If the surface is referenced by another civil 3d object you will not have the option to delete it.   Examples: a profile, pipe, structure, corridor, grading, or if the surface is pasted into another surface.
Mark Mccall
CAD Mangler
VHB - Vanasse Hangen Brustlin, Inc.
Linkedin
Message 8 of 14
deltacoolguy
OMG!  That worked.
Windows 10-64 Pro
8GB RAM (Home)
12GB RAM (Work)
AutoCAD Civil 3D 2019
Message 9 of 14
autoMick
I use the method above and it works regularly for me.
Make sure that the surface is not referenced by another surface, or a profile, grading, etc. If it is you will need to remove it from the applicable definition.
Cheers
Mick
Civil3d user in Australia since 2012.
Message 10 of 14
user181
If you use the right click select method in prospector and then move the cross hairs away from the palette and over the drawing area and hit the delete key it will delete the surface EVEN IF IT IS REFERENCED in a profile, cross sections, volume surface, etc.  So one should use caution and be sure they don't need it anymore
Message 11 of 14
autoMick
Good point! I should've added in my previous post that I only use the right-click-select then del option if the normal method for deleting a surface is unreasonably not available.
Cheers
Mick
Message 12 of 14
mzionE27X2
Community Visitor
Community Visitor
This worked - thanks
Message 13 of 14
Joe-Bouza
highlight surface collection in prospector, down in panorama, righ click should show delete.
Or select and delete
Joe Bouza
Message 14 of 14
alan676415
Right click mouse on the name then, there is option will appear "Select" then type e in the command line.
It will delete.
